Aim Universal Steering Wheel Hub Bracket
Mount Your System
The Aim Universal Steering Wheel Hub Bracket is a versatile mounting solution designed to position your dash logger display on the steering column side of your quick-release steering wheel. Constructed from 2mm thick raw stainless steel, this hub offers durability and a sleek, minimalist appearance.
Why Choose the Aim Steering Wheel Hub Bracket
The Universal Steering Hub Bracket features a 6-bolt pattern with 70mm and 76mm PCD (Pitch Circle Diameter), making it compatible with most 6-bolt steering wheels. Its universal design allows for easy integration into various setups, providing a stable and secure mounting point for your dash logger.
Please Note: If your steering wheel has a low or no dish, you may require a 3mm hub spacer to ensure sufficient clearance for the bolt heads.
Styrnavsfäste
