Hoppa till innehåll
Logga in
Sök
Sök Logga in Din kundvagn 0
Din kundvagn
  • Fortsätt handla
    Delsumma
    Se din kundvagn
    Sök
    Ducati Panigale V4/V2 AiM EVO4S Logger Plug & Play Cable - AimShop.com
    DUC-PP-EVO
    Ducati Panigale V4/V2 Aim EVO4S Logger Plug & Play Cable
    I lager, redo att skickas
    £70.00
    • Dela på Facebook
    • Dela på WhatsApp
    • Dela på Email
    • Facebook Dela på Facebook
    • WhatsApp Dela på WhatsApp
    • E-mail Dela på Email
    £70.00
    Ducati Panigale V4/V2 AiM EVO4S Plug & Play Cable
    The AiM ECU plug & play cable has been specifically designed for Ducati Panigale V4/V2 bikes. Allowing easy installation to an EVO4S Data Logger. With a 7-pin 712 male binder connection.
    Ducati Panigale V4/V2 plug & play cable 7 pin - 712 male binder connection
    Receive data Suitable for EVO4S
    Ducati Panigale V4/V2 Plug & Play ECU Cable
    The AiM ECU plug & play cable has been specifically designed for the Ducati Panigale V4/V2 bike. This plug & play cable can be used for the EVO4S Data Logger.
    The plug & play cable currently fits the following Ducati Panigale bike models:
    Panigale V4 - From 2018 Panigale V2 - From 2020
    Example data protocols
    • Below is a pinout drawing for the Ducati Panigale V4/V2 plug & play connection cable
    • Ducati Panigale V4/V2 Plug & Play connection cable
    Technical sheet Race Studio 3
    • Öppnas i ett nytt fönster.
