Grå 35-stifts AMP PDM Plug Connector Hölje
Connect Your System
The Grey 35-Pin AMP PDM Plug Connector provides a rugged housing socket for PDM connection harnesses. It's highly reliable under high temperatures and has an IP67 rating, making it extremely water and dust-resistant.
Why Choose the Aim 35-Pin Grey AMP Connector Plug
The 35-Pin AMP Plug Connector is a brilliant and rugged connector housing that can withstand extremely high temperatures (-40°C to +125°C). It has a 2-piece contact hold design with secondary locking to prevent the contact from getting torn out under harsh conditions. These connectors accept a wire size of 0.5 to 1.25mm².
Grey 35-Pin AMP Plug Housing Socket
