Hoppa till innehåll
Logga in
Sök
Sök Logga in Din kundvagn 1
Din kundvagn
Du har nått fri frakt!
  • AiM Accessories CAN Open keypad for race car accessories, compact black control panel with labeled buttons
    K-seriens knappsatser ÖPPNA - K6 / K8 / K15
    £190.00
    Ta bort
Delsumma
£190.00
Se din kundvagn
Sök
Link BAL6 ballast resistor for ignition and injection systems, shown on a plain background
Link BAL6 ballast resistor for ignition and injection systems, shown on a white background
BAL6
Link Ballast Resistor (BAL6)
Reapris£85.00
Ordinarie pris £100.00
  • Dela på Facebook
  • Dela på WhatsApp
  • Dela på Email
  • Facebook Dela på Facebook
  • WhatsApp Dela på WhatsApp
  • E-mail Dela på Email
Reapris£85.00Ordinarie pris £100.00
For use with low-impedance injectors. Compatible with injectors with impedance between 2 and 6 Ohms. Please contact us if you are planning on using injectors with an impedance of fewer than 2 ohms.
Includes set of 6 x 4.7ohm 25w resistors mounted to a heatsink. These are also sold in a set of 4.
Note that injector ballast resistors get quite hot at high injector duty cycles. These should stay mounted on the supplied heat sink and be bolted to the chassis.
  • 6 x 4.7 ohm 25w mounted to a heatsink
  • Vanliga frågor
  • Programvara
  • Supportvideor
  • Produktguide PDF
  • Kontakta oss
  • Bli ambassadör
  • Reparationer
  • Livechatt & Support
  • Öppnas i ett nytt fönster.
