Hoppa till innehåll
Logga in
Sök
Sök Logga in Din kundvagn 0
Din kundvagn
  • Fortsätt handla
    Delsumma
    Se din kundvagn
    Sök
    Link MINIX PlugIn ECU for MINI Hatch R50–R53, compact plug-in engine control unit module
    Link MINIX PlugIn ECU for MINI Hatch R50–R53, Link Plug In ECU module with connector pins
    MINIX
    MINI Hatch R50 – R53 Link - MINIX PlugIn ECU
    Reapris£1,147.50
    Ordinarie pris £1,275.00
    • Dela på Facebook
    • Dela på WhatsApp
    • Dela på Email
    • Facebook Dela på Facebook
    • WhatsApp Dela på WhatsApp
    • E-mail Dela på Email
    Reapris£1,147.50Ordinarie pris £1,275.00
    Our ECU comes in its own case which fits directly into the factory location.
    Installation is a breeze, with no alteration of the factory wiring loom required for the models listed below.
    This ECU is designed for the R50-R53 Tritec 1.6 SC engine.
    Please check your pinout connector matches the header in the listed photo before purchasing.
    An XS Loom and 4 Bar Map Sensor highly recommended (sold separately).
    Suitable Applications:
    R50 –R53 MINI Hatch with the 1.6l SC engine
    *Chronopack dash option not currently supported
    PlugIn Key Features (where applicable):
    Sequential fuel delivery
    OEM idle hardware supported
    CAN port
    USB tuning cable included
    Staged injection
    Knock with "windowing"
    I/O Expansion Options:
    Aux1 -  Auxiliary Output
    DI8 -  Digital Input
    DI9 -  Digital Input
    An Temp 3 -  Temperature sensor input
    An Temp 4 -  Temperature sensor input
    An Volt 10 -  Analog 0-5V input
    An Volt 11 -  Analog 0-5V input
    +5V Out -  Low Current +5V Supply
    GND -  Sensor Ground Only
    *Please see the PC Link Help file for details regarding installing the Expansion Cable.
    MINI hatch R50 – R53 Link - MINIX PlugIn ECU
    • G4X PlugIn ECU
    • Stickers
    • Vanliga frågor
    • Programvara
    • Supportvideor
    • Produktguide PDF
    • Kontakta oss
    • Bli ambassadör
    • Reparationer
    • Livechatt & Support
    • Öppnas i ett nytt fönster.
