Hoppa till innehåll
Logga in
Sök
Sök Logga in Din kundvagn 1
Din kundvagn
Du har nått fri frakt!
  • Link Subaru WRXLink V10 WRX107X plug-in ECU, Link Plug In ECU module
    Link Subaru WRXLink (V10) - WRX107X PlugIn ECU
    £1,246.50
    Ta bort
Delsumma
£1,246.50
Se din kundvagn
Sök
WRX107X
Reapris£1,246.50
Ordinarie pris £1,385.00
  • Dela på Facebook
  • Dela på WhatsApp
  • Dela på Email
  • Facebook Dela på Facebook
  • WhatsApp Dela på WhatsApp
  • E-mail Dela på Email
Reapris£1,246.50Ordinarie pris £1,385.00
Designed for the WRX V10 EJ25. These ECUs cover 2.5L from 2004 to 2007.
Air temp sensor highly recommended.
Suitable Applications:
The WRX104+mostly covered the 2004-2006 range (listed separately).
The WRX107+ mostly covers the 2007 model.
However, some 2006 models require the WRX107+
*The fastest and most reliable way to tell, is to check whether pins A1-3 are populated.
*If the pins have wires, you need the WRX104+, if there are no wires, you need the WRX107+
*Suits GD or GG chassis with electronic throttle. Not suitable for the GR/GH/GE/GV hatchback or 3rd generation WRX’s
PlugIn Key Features:
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
There are two different options for the expansion connectors, depending on whether your ECU is the 2004-2006 ECU or the 2006-2007 ECU.
2004-2006 ECU
Blank AN Volt 11
Blank No function
Blank AN Volt 12
Blank No function
Blank No function
Gnd Sensor Ground Only
2006-2007 ECU
The 2006-2007 V10 ECU contains an 8 pin expansion connector.
Aux 11 Auxiliary Output
Aux 12 Auxiliary Output
Volt 11 Analog 0-5V input
Aux 13 Auxiliary Output
DI 11 Digital Input
  • G4X PlugIn ECU
  • Stickers
  • Vanliga frågor
  • Programvara
  • Supportvideor
  • Produktguide PDF
  • Kontakta oss
  • Bli ambassadör
  • Reparationer
  • Livechatt & Support
  • Öppnas i ett nytt fönster.
