Hoppa till innehåll
Logga in
Sök
Sök Logga in Din kundvagn 0
Din kundvagn
  • Fortsätt handla
    Delsumma
    Se din kundvagn
    Sök
    Link Toyota MR2Link V1 TST185X PlugIn ECU module for Toyota MR2
    Link Toyota MR2Link V1 TST185X PlugIn ECU for Toyota MR2 performance tuning
    TST185X
    Link Toyota MR2Link V1 - TST185X PlugIn ECU
    Reapris£1,012.50
    Ordinarie pris £1,125.00
    • Dela på Facebook
    • Dela på WhatsApp
    • Dela på Email
    • Facebook Dela på Facebook
    • WhatsApp Dela på WhatsApp
    • E-mail Dela på Email
    Reapris£1,012.50Ordinarie pris £1,125.00
    Designed for the 3SGTE engine in the models specified below.
    A Link Air Temp Sensor is highly recommended with this ECU
    Suitable Applications:
    Toyota MR2 (SW20) from 1989 to 1992
    Toyota Celica ST185 (except the GT-Four RC/Carlos Sainz Special Edition which is compatible with the Link TST205X Plugin)
    Sequential fuel delivery
    OEM idle hardware supported
    CAN port
    USB tuning cable included
    Staged injection
    Knock with "windowing"
    I/O Expansion Options:
    Expansion connector:
    Gnd Sensor Ground Only
    DI 5 Digital Input for switching functions.
    DI 6 Digital Input for switching functions.
    DI 4 Digital Input for switching functions.
    An Volt 4 Analog 0-5V input
    An Volt 5 Analog 0-5V input
    An Volt 6 Analog 0-5V input
    An ignition expansion is provided allowing you to convert to a Direct Spark ignition system. Alternatively, these outputs can be used to drive auxiliary devices. The following pinout describes the available connections.
    Ignition Expansion:
    1 Ignition 1
    2 Ignition 2
    3 Ignition 4
    4 Ignition 3
    • G4X PlugIn ECU
    • Stickers
    • Vanliga frågor
    • Programvara
    • Supportvideor
    • Produktguide PDF
    • Kontakta oss
    • Bli ambassadör
    • Reparationer
    • Livechatt & Support
    • Öppnas i ett nytt fönster.
