Hoppa till innehåll
Logga in
Sök
Sök Logga in Din kundvagn 1
Din kundvagn
Du har nått fri frakt!
  • Link crank angle sensor (CAS) for engine timing and trigger system applications
    Link Crank Angle Sensor (CAS)
    £104.80
    Ta bort
Delsumma
£104.80
Se din kundvagn
Sök
Link TTX PlugIn ECU for Audi TT, compact plug-in engine control unit by Link
Link TTX PlugIn ECU for Audi TT, compact electronic control unit module from Link
TTX
Link Audi TTLink - TTX PlugIn ECU
Reapris£1,147.50
Ordinarie pris £1,275.00
  • Dela på Facebook
  • Dela på WhatsApp
  • Dela på Email
  • Facebook Dela på Facebook
  • WhatsApp Dela på WhatsApp
  • E-mail Dela på Email
Reapris£1,147.50Ordinarie pris £1,275.00
G4X PlugIn ECUs offer the latest in engine management technology, designed to maximize the potential of your car.
This ECU fits in the factory OEM location. Installation is a breeze, with no alteration of the factory wiring loom required for the models listed below.
The Link G4X ECU TTLink TTX PlugIn Designed for the VWAG PQ34 1.8l Turbo engine with E-Throttle.
This ECU works with manual transmissions only.
Includes an onboard 4 bar or 7 bar MAP sensor.
Suitable Applications:
The engine must be 1.8T
ECU header must have two connectors, 121 pin total
Must be Drive by Wire (E-throttle)
Must be manual transmission
FWD or 4WD (Haldex)
p to 6D fuel and ignition mapping
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
Expansion connector 2
There is no separate expansion connector on the TT Link.
Pin 110 - An Temp 3
Pin 111 - An Volt 10
Pin 112 - DI9
Pin 113 - Ign 6
  • G4X PlugIn ECU
  • Stickers
Compatibility
The following vehicles are known to be compatible:
Audi TT - 99-02 - AJQ
VW Beetle - 2005 - AWU
VW Passat - 2000
VW Golf - 2001 - AUM
The following vehicles are likely to be compatible with the ECU, but are untested:
Make
Model
Years
Engine code
Audi
A3
98-00
AJQ
A3
99-00
APP
A3
99-01
ARZ
A3
00-05
ARX
A3
00-05
ARY
A3
00-05
AUM
A3
00-05
AUQ
A4
98-00
APU
A4
00-02
AVJ
A4
00-02
AWT
A4
02-03
BEX
A4
04-07
BFB
A6
98-00
APU
A6
00-02
AWT
S3
98-01
APY
S3
00-05
BAM
S3
02-03
AMK
TT
98-00
APX
TT
99-00
APP
TT
99-02
AJQ
TT
00-02
AMU
TT
00-05
ARX
TT
00-05
ARY
TT
00-05
AUM
TT
00-05
AUQ
TT
00-05
BAM
TT
00-06
AWP
TT
05-06
BFV
TT
05-06
BVP
TT
05-06
BVR
Seat
Alhambra
00-04
AWC
Ibiza
99-00
AQX
Ibiza
00-01
AYP
Ibiza
04-08
BJX
Ibiza
05-08
BBU
Leon
98-00
AJQ
Leon
99-00
APP
Leon
00-01
AJQ
Leon
00-05
ARY
Leon
00-05
AUQ
Leon
00-05
BAM
Leon
02-03
AMK
Skoda
Octavia
99-01
ARZ
Octavia
00-05
ARX
Octavia
00-05
ARY
Octavia
00-05
AUM
Octavia
00-05
AUQ
VW
Bora
00-05
ARX
Bora
00-05
ARY
Bora
00-05
AUM
Bora
00-05
AUQ
Bora
02-06
AWP
Golf
99-01
ARZ
Golf
00-05
ARX
Golf
00-05
ARY
Golf
00-05
AUM
Golf
00-05
AUQ
Golf
02
AWP
Golf
02-06
AWP
Jetta
01-09
AWP
New Beetle
99-00
APH
New Beetle
99-00
AVC
New Beetle
02-04
AWP
Passat
98-00
APU
Passat
00-02
AWT
Polo
04-08
BJX
Polo
05
AWP
Polo
05-08
BBU
Sharan
00-04
AWC
Vehicles with the following engine codes are known not to be compatible:
AEB, AGU, AJH, AJL
  • Vanliga frågor
  • Programvara
  • Supportvideor
  • Produktguide PDF
  • Kontakta oss
  • Bli ambassadör
  • Reparationer
  • Livechatt & Support
  • Öppnas i ett nytt fönster.
