Hoppa till innehåll
Logga in
Sök
Sök Logga in Din kundvagn 0
Din kundvagn
  • Fortsätt handla
    Delsumma
    Se din kundvagn
    Sök
    Link XS Expansion Loom #XSL cable for Link loom systems
    Link XS Expansion Loom #XSL by Link for loom and cable exercises
    XSL
    Reapris£29.75
    Ordinarie pris £35.00
    • Dela på Facebook
    • Dela på WhatsApp
    • Dela på Email
    • Facebook Dela på Facebook
    • WhatsApp Dela på WhatsApp
    • E-mail Dela på Email
    Reapris£29.75Ordinarie pris £35.00
    Want to add additional inputs/output to your Link Plugin ECU? Use the XS Loom. The Link XS Loom plugs into the expansion connector on all Link G4, G4+ and G4X plug-in ECUs.
    The number of extra inputs and outputs added by the XS Loom is dependent on the Plugin ECU. For specific details check the plug-in ECUs specifications.
    Common applications include but are not limited to:
    Boost adjustment knob or switch
    Wide-band AFR/Lambda
    Oil Pressure Sensor
    Fuel Pressure Sensor
    Inlet Air Temperature (IAT) sensor
    Map switch (Different tunes available via toggle switch)
    The XS Loom is 2.5m long and uses 20AWG wire.
    • XS Loom 2.5m
    • Vanliga frågor
    • Programvara
    • Supportvideor
    • Produktguide PDF
    • Kontakta oss
    • Bli ambassadör
    • Reparationer
    • Livechatt & Support
    • Öppnas i ett nytt fönster.
