Hoppa till innehåll
Logga in
Sök
Sök Logga in Din kundvagn 0
Din kundvagn
  • Fortsätt handla
    Delsumma
    Se din kundvagn
    Sök
    Link BMWLink E36X PlugIn ECU for BMW E36 vehicles
    Link BMWLink E36X PlugIn ECU for BMW vehicles
    Link BMWLink E36X PlugIn ECU for BMW E36, plug-in engine control unit shown from above
    E36X
    Link BMWLink - E36X PlugIn ECU
    £1,145.00
    • Dela på Facebook
    • Dela på WhatsApp
    • Dela på Email
    • Facebook Dela på Facebook
    • WhatsApp Dela på WhatsApp
    • E-mail Dela på Email
    £1,145.00
    Link BMW Link - E36X ECU PlugIn ECU
    This ECU is designed for the E36 M50TUB25 engine.
    This ECU only works with the Engine Code M50TUB25 (Bosch ECU from the factory).
    Works with manual & automatic transmissions.
    Built-in 4 Bar MAP sensor or 7 Bar MAP sensor included.
    Suitable Applications:
    M50TUB25 engine with the Bosch M3.3.1 ECU from factory
    Sequential fuel delivery
    OEM idle hardware supported
    CAN port
    USB tuning cable included
    Staged injection
    Knock with "windowing"
    Expansion connector - The following expansion connector inputs/outputs are provided:
    TEMP3 Temperature sensor input
    TEMP4 Temperature sensor input
    VOLT4 Analog 0-5V input
    VOLT5 Analog 0-5V input
    DI8 Digital Input
    DI7 Digital Input
    +5V Low Current +5V Supply
    GND Sensor Ground Only
    *Please see the PC Link Help file for details regarding installing the Expansion Cable.
    • G4X PlugIn ECU
    • Stickers
    • Vanliga frågor
    • Programvara
    • Supportvideor
    • Produktguide PDF
    • Kontakta oss
    • Bli ambassadör
    • Reparationer
    • Livechatt & Support
    • Öppnas i ett nytt fönster.
