The Ultimate Mountain Bike Setup
Combine the XLog, a small, waterproof, 25Hz GPS data logger; the ACC3, our unbeaten Analogue CAN Converter; Suspension Potentiometers, and you can even connect the ultimate camera - the SmartyCam 3 Sport, to become the best rider and beat your best lap times.
Why Choose the XLog Mountain Bike Kit
It provides a powerful solution for anyone who wants to capture and analyse their performance data without needing an on-board display. Combined with the ACC3 and Suspension Potentiometers, you will find the ultimate key to control, analysis and improvement.
AiM Motorcycle XLog motorcycle data logging kit with compact black data logger unit
Downhill mountain bike
XLog Features
  • Lap times
  • Sector times
  • Vehicle position and speed
  • 3D acceleration and gyro
In addition, the XLog features a second CAN for connecting an external device or Aim Expansion, meaning you can add brake pressure sensors, analogue inputs, and a professional motorsport camera for enhanced functionalities.
ACC3 with 4 channel harness
The Aim ACC3 is an Analogue CAN Converter, built practically for a range of motorsport disciplines, including downhill mountain bike applications. Its compact design ensures easy installation across a range of racing disciplines, while its robust construction guarantees reliability in demanding environments. When combined with Race Studio 3 software, the ACC3 unlocks powerful configuration and analysis tools, including suspension analysis with Aim Eclipse sensors and video synchronisation with SmartyCam 3 cameras.
The ACC3 supports up to 4 analogue inputs with frequencies up to 200Hz.
Inertial Platform in XLog
XLog GPS & Inertial Platform
  • Lap Timing & Sectors: Samples laps and sectors, and provides all the raw data for Race Studio 3 analysis.
Compact, Durable Design
Measuring only 72.3 × 65.3 × 30.3mm, the XLog is compact to fit in even the tightest setup. Its rugged, waterproof housing ensures reliable operation in all conditions. With a built-in rechargeable lithium battery (up to 10 hours) and support for an external 8–16V supply, the XLog is built for trackside convenience.
Analyse with Race Studio 3
Analyse lap times, sector times, GPS maps, accelerations, and video (when paired with a SmartyCam 3) to improve your performance and understand your bike in detail.
Expand your XLog with ACC3, Data Hub and sensors
The XLog features a second CAN for connecting an external device or Aim Expansion, meaning you can integrate brake pressure sensors and a professional motorsport camera for enhanced functionalities.
Integrate the ACC3 that comes in the kit to sample data coming from suspension and pressure; you will also be able to integrate a SmartyCam 3, sold separately, taking your data to the next level by incorporating synchronised video footage to overlay the data recorded by the XLog data logger onto your footage post-session with Race Studio 3.
XLog
  • USB Connection: Yes
  • GPS: 25Hz
  • Wi-Fi: Built in
  • Bluetooth: Built in
  • Expansions: ACC3, Lambda Sensors, SmartyCam
  • RPM Input: 1
  • Push Button: 1
  • Status LED: 1
  • External Power: 9-15V
  • Weight: 150g approx.
SKU: XLOG
ACC3
  • Connection: CAN
  • Material: PA6 30% glass
  • Weight: 50g
  • Waterproof: IP65
SKU: ACC
ACC diagram
ACC3 pinout
XLog User Guide
XLog Tech Sheet
ACC Användarhandbok
ACC Tech Sheet
Rose End Tech Sheet
Pop End Tech Sheet
