This MyChron 4 is fully equipped and ready to take on its second life. The product is in full working order at a reduced price, and has been meticulously checked by our technicians.
A Modular Logger Perfect for Beginners and Professionals
The MyChron4 is the most complete tool to sample, show and record the key-data of your kart. Thanks to its modularity, MyChron4 can supply either beginners with the essential information and professionals with extremely detailed and sophisticated data.
Second-Life ur produktion <tc>Aim</tc> MyChron 5S Karting Varvtimer (Sensorer ingår ej)
Why Choose the MyChron 4 GPS Lap Timer 
The MyChron 4, in its base configuration, samples:
  • Magnetic and optical lap times
  • RPM graphically displayed on a freely configurable scale
  • One temperature (water, underspark or exhaust gas).
At the end of your session you can scroll all relevant data on the display:
  • Lap times, with best lap indication
  • Max RPM
  • Max temperature value
Advanced Display
The graphical display is backlighted and protected by transparent, non-reflecting polycarbonate.
Data are recorded in its circular buffer, with a capacity of 4 millions samples and downloaded via the Aim Data Key to your PC for post analysis with the professional Race Studio software.
Your growth as racer makes you more demanding: you need more sophisticated data, you need a deeper understanding of your kart and your on-track behaviour.
The MyChron 4 grows with you. Simply adding new modules you will get all the information you need:
  • Dimensions: 125.7 x 87.7 x 20.5mm
  • Weight: 293g
Pinouts
MyChron 4 User Guide
