Hoppa till innehåll
Logga in
Sök
Sök Logga in Din kundvagn 0
Din kundvagn
  • Fortsätt handla
    Delsumma
    Se din kundvagn
    Sök
    Suzuki GSX-R 600, 750, 1000 AiM Solo 2 DL & EVO4S Logger Plug & Play Cable - AimShop.com
    SUZ-PP
    Suzuki GSX-R 600, 750, 1000 Aim Solo 2 DL & EVO4S Logger Plug & Play Cable
    I lager, redo att skickas
    £70.00
    • Dela på Facebook
    • Dela på WhatsApp
    • Dela på Email
    • Facebook Dela på Facebook
    • WhatsApp Dela på WhatsApp
    • E-mail Dela på Email
    £70.00
    Suzuki GSX-R 600, 750, 1000 Solo 2 DL & EVO4S Plug & Play Cable
    The AiM ECU plug & play cable has been specifically designed for Suzuki bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.
    Suzuki plug & play cable 7 pin - 712 male binder connection
    Suzuki Plug & Play ECU Cable
    The AiM ECU plug & play cable has been specifically designed for the Suzuki bike. This plug & play cable can be used for the Solo 2 DL and EVO4S Data Logger.
    GSX-R600 - 2006-2019 GSX-R750 - 2006-2019
    GSX-R1000 - 2005-2019 GSX-R1300 Hayabusa Gen.2 - 2008-2016
    Example data protocols
    • Below is a pinout drawing for the Suzuki Solo 2 DL and EVO4S Data Logger plug & play connection cable
    • Suzuki GSX-R Plug & Play connection cable
    Technical sheet Race Studio 3
    • Öppnas i ett nytt fönster.
