Aim شاشة عرض GS-Dash للدراجات النارية مع مسجل بيانات XLog
The Ultimate Rider Setup
Combine the XLog, a small, waterproof, 25Hz GPS data logger; the ACC3, our unbeaten Analogue CAN Converter; Suspension Potentiometers; Brake Pressure Sensors, and you can even connect the ultimate motorcycle camera - the SmartyCam GP, to become the best rider and beat your best lap times.
Why Choose the XLog Motorcycle Kit
It provides a powerful solution for anyone who wants to capture and analyse their performance data without needing an on-board display. Combined with the ACC3, Suspension Potentiometers and Brake Pressure Sensors, you will find the ultimate key to control, analysis and improvement.
GS-Dash Features
The compact dimensions of the GS-Dash make it particularly suitable for motorcycles. Manufactured in aluminium with edge-to-edge glass and metallic push buttons, the Aim GS-Dash is robust and fully waterproof.
It displays racing data from the bike's ECU, from the accelerometers, GPS and any custom sensors, and it features connectivity with the XLog with minimum effort.
The GS-Dash can perform some operations via a pop-up keyboard. These include:
- Enabling/disabling the backlight
- Selecting the nearest track to race
- Checking GS-Dash firmware version
- Deleting the data stored on the XLog
XLog Features
The XLog calculates and records:
- Lap times
- Sector times
- Vehicle position and speed
- 3D acceleration and gyro
- ECU data via CAN, K-Line or RS232 connections.
(You can select the protocol of your car/bike among thousands of pre-defined protocols, or easily develop your own). - Digital RPM input from the primary of the coil (150-400V) or from a square wave (8-50V) when no ECU connection is available.
In addition, the XLog features a second CAN for connecting an external device or Aim Expansion, meaning you can add a Lambda Controller, analogue inputs, and a professional motorsport camera for enhanced functionalities.
XLog GPS & Inertial Platform
- GPS Technology: Tracks position and speed at 25Hz using four satellite constellations (GPS, GLONASS, BeiDou, Galileo) with <0.5m precision.
- 6-Axis IMU: Records 3D accelerations and angular velocity at 100Hz, allowing in-depth analysis of braking, acceleration, and chassis behaviour.
- Lap Timing & Sectors: Automatically recognises track layouts, samples laps and sectors, and provides all the raw data for Race Studio 3 analysis.
The GS-Dash can be backlit in one of eight available colours; it also features an ambient light sensor that makes brightness and contrast ideal in all light conditions.
The GS-Dash can also swap among pages showing lap times and data in a customisable way to suit your needs. Choose the data and create pages displaying up to eight fields in each. You can visualise the rolling time, static or predictive lap time (as an absolute value or as a difference vs. the best lap).
XLog Connectivity
- ECU Connection: Supports thousands of predefined CAN, RS232, or K-Line protocols, or you can build your own protocol via CAN builder.
- Second CAN Option: Configure for Aim expansions, or connect additional sensors and third-party CAN devices.
- Wireless: Integrated Wi-Fi and Bluetooth for fast, cable-free data transfer.
- USB-C & Memory Key: 4GB internal memory plus a removable 16GB USB-C key for quick access.
Compact, Durable Design
Analyse with Race Studio 3
The XLog data logger works seamlessly with Aim’s ecosystem of devices thanks to its second CAN connection. The second CAN option can be used for Aim Expansions or to connect sensors and other devices that communicate via CAN and use existing protocols or create a dedicated protocol for the second CAN.
- ACC3 Analogue to CAN Converter: Add up to four analogue channels for pressure, temperature, suspension, and other sensors.
- LCU-One Lambda Controller: Capture air/fuel ratios and exhaust data for tuning and performance optimisation.
- SmartyCam: Overlay logged data directly onto video for detailed driver analysis.
- Data Hub: Split EXP ports to connect multiple expansions such as GS-Dash displays, Lambda controllers, or additional converters.
GS-Dash with Spiral Cable
XLog
Your Chosen Harness
How does the Aim GS-Dash Motorcycle Racing Dash Display work?
The Aim GS-Dash is a display that connects directly to a data logger via CAN, drawing power and data through a single cable. Once set up, it displays the information collected by the logger, such as RPM, temperature and any personalised configurations. You can fully customise the display on the dash using our free Race Studio 3 software, picking which data you want to see on-screen. You can also have multiple pages, allowing you to switch through various data sets.
