Mychron Expansion Box with External Power Lead – AimShop.com
SKU: MY4-EX
Availability: 34 in stock
£228.00
QTY:
Trust Badge
The Aim Mychron Expansion Box with External Power Lead is the new channel multiplier improving MyChron5 and MyChron5 2T performances with the four additional channels and a further connector for the CAN bus.
Through this last connector The MyChron5 can be connected to another Aim system via LCU Lambda controller, GPS Module or the SmartyCam the on-board camera or a Data key for data download.
Thanks to its specific wiring, the MyChron Expansion powers MyChron5 and its peripherals with an external battery, avoiding internal battery consumption. MyChron Expansion features four inputs to connect MyChron5 to an equal number of additional channels.
All channels are easily configurable as analog through MyChron4 menu to sample data outcoming from:
  • Exhaust gas valve position sensor (very important to understand at which RPM value the exhaust port opens)
  •     Wheel speed sensor: the first input on the left can be configured also as digital input
  •     No contact brake pedal position sensor
  •     No contact throttle pedal position sensor (to know if and when to accelerate)
  •     Brake pressure sensor
  •     Water temperature or cylinder head temperature (PT100 thermo-resistor only)
  •     Steering angle potentiometer (to highlight over/under steering situations)
  •     Brake pedal potentiometer
  •     Throttle pedal potentiometer
MyChron Expansion is a complete, value-for-money instrument for professional kart analysis.
Connection Examples
Standard Configuration
Connection example
Connection Examples
mychron expansion connection example 2
Warning: MyChron Expansion DOES NOT support gear calculation.
This expansion is to be considered as alternative to MyChron4 eBox.
Technical Specifications
Dimensions: 127x24x33 mm
Weight: 194 g
Sampling frequency: 10 Hz
User manual ver. 1.03
Pinout ver. 1.01
Pictures
