5-pin til 7-pin åbent CAN-kabel
Aim CAN Cable for Open Products
The Aim CAN Connection Cable is used to connect Open systems to Aim devices. Featuring a 5-pin male binder and an Open 7-pin CAN connector in a standard 1m length, this cable is ideal for linking external Open systems with Aim devices, for a clean, reliable Aim CAN setup.
Why Choose the 5-Pin to 7-Pin Open CAN Cable
This high-quality cable ensures stable communication and accurate data transfer between compatible Aim devices. Built for durability, the 5-pin – 7-pin Open CAN Cable maintains a strong connection even in the harshest conditions.
Åbn CAN-kabel
