Aim 37-benet Deutsch-ledningsnet til MX-serien
Deutsch Harness for MX Display Loggers
The Aim 37-Pin Deutsch Harness is the standard harness that comes with Aim MX Loggers. The 37-Pin Deutsch Harness includes a 37-pin Deutsch female flying connector, 4-pin 719 female binders and 5-pin 712 female binders. It connects into the 37-pin socket on your MX Data Logger, giving you access to analogue sensor channels (1-4), digital wheel speed sensor input, CAN expansion, Power+, Ground-, CAN ECU connection and K-Line.
Why Choose the Aim 37-Pin Deutsch Harness
The Aim 37-Pin Deutsch Harness is designed to work with Aim MX Display Loggers in race or track vehicles. When combined with the optional 22-Pin Deutsch Harness, both harnesses can offer additional analogue channels and advanced functions in a compact, motorsport-ready package.
The standard 37-Pin Harness that comes with the logger supports 4 primary analogue channels, including water temperature, oil temperature, oil pressure and brake pressure. The 37-Pin Harness is also available with one or two pre-wired thermocouple connectors, allowing you to connect K-Type thermocouple sensors to measure things like exhaust gas temperature (EGT) directly from the harness.
37-Pin MX Logger Deutsch Harness
