Aim 712 Male 7-Pin to 712 Male 5-Pin SmartyCam CAN Cable
Power Your System
The Aim SmartyCam CAN Bus Cable provides a constant power supply from an external Aim device. The cable is available in 2 or 4 metre lengths and is compatible with the Aim SmartyCam 2.1 HD models.
Why Choose the SmartyCam Power Cable
This connection cable is required if you are connecting the SmartyCam 2.1 camera to a logger or dash, as the power will be supplied to the camera through the CAN bus connection. It features a 7-pin and 5-pin 712 male binder on either end to connect the devices.
Please Note: The Aim 712 Male 7-Pin to 712 Male 5-Pin SmartyCam CAN Cable is ONLY compatible with the SmartyCam 2.1 models. It cannot be used with newer SmartyCam models.
