Springe
Log ind
Søg her
Søg her Log ind Indkøbskurv 0
Indkøbskurv
Din indkøbskurv er tom
  • Fortsætte med at handle
    Skriv din besked
    I alt
    Se indkøbskurv
    Søg her
    Aim DTA S60 Interface Lead MXL Evo - AimShop.com
    ECU-DTA
    På lager, klar til afsendelse
    £80.00
    • Del på facebook
    • Del på WhatsApp
    • Del på e-mail
    • Facebook Del på facebook
    • WhatsApp Del på WhatsApp
    • E-mail Del på e-mail
    £80.00
    Aim DTA S60 Interface Lead MXL EVO
    Aim Looms, Cables, Connectors and Harnesses are highly engineered to withstand the intense rigours of the Motorsport environment.
    Aim developed special applications for many of the most popular ECUs. By special applications, we mean user-friendly systems which allow you to easily connect your ECU to our high tech data logger. You only need to install a harness between the logger and the ECU.
    Once connected, the logger displays (and/or records depending on the logger on the ECU data stream and configuration) values like RPM, engine load, throttle position (TPS), air and water temperatures, battery voltage, speed, gear, lambda value (air/fuel ratio) analogue channels
    • Opdater siden
    • Åbn i et nyt vindue
