Aim Handlebar Bar Pad Mount for Solo 2 & Solo 2 DL
Mount Your System
The Aim Bar Pad Mount secures any Aim Solo 2 GPS Lap Timer to the handlebars, so that you can easily and accurately measure your lap times. It is predominantly designed for motocross handlebars, but can also fit standard motorcycle and off-road vehicle handlebars with or without a cross brace.
Why Choose the Aim Solo 2 Bar Pad Mount
Designed specifically for the Aim Solo 2 and Solo 2 DL, the bar pad provides a strong and secure mounting solution, ensuring the lap timer won’t move, fall or cause any distractions to the rider. It comes with a transparent protective cover, a shock-protected Solo 2/2DL unit mount, a fixing bracket and 4 x 12mm M3 screws, ensuring that your lap timer is protected against the harsh environment of off-road riding.
Please Note: The Solo 2 is not included, the image is to show what the bar pad will look like when fitted with a GPS lap timer.
Chosen Solo 2 Bar Pad
Transparent Protective Cover
Bar Pad Mounting Bracket
4 x 12mm M3 Screws
