Springe
Log ind
Søg her
Søg her Log ind Indkøbskurv 0
Indkøbskurv
Din indkøbskurv er tom
  • Fortsætte med at handle
    Skriv din besked
    I alt
    Se indkøbskurv
    Søg her
    Aim MyChron Magnetic Lap Receiver - AimShop.com
    S-MG
    På lager, klar til afsendelse
    £125.00
    • Del på facebook
    • Del på WhatsApp
    • Del på e-mail
    • Facebook Del på facebook
    • WhatsApp Del på WhatsApp
    • E-mail Del på e-mail
    £125.00
    AiM MyChron Magnetic Lap Receiver
    This magnetic lap timing receiver is compatible with the Aim MyChron lap timers and directly replaces the sensor supplied initially with the MyChron4. You can also use it with the MyChron5 if GPS is not available.
    Magnetic lap receiver 712 - 4 pin binder connector
    Suitable for MyChron 4, 5 & 6
    The sensor triggers the timer when it passes over the magnetic timing strip fitted to most kart tracks.
    Replacement sensor for MyChron4
    Compatible with MyChron5
    Triggers lap times from the magnetic strip found in kart tracks
    • 712 - 4 pins Binder Connector
    • 1 x AiM Magnetic Lap Receiver
    • Opdater siden
    • Åbn i et nyt vindue
