Power Your System
The Aim SmartyCam ECU Harness provides a direct power supply to the Aim SmartyCam 2.2 & 3 GP & Corsa cameras. It provides direct power from your vehicles 12V system and features a 712 7-pin binder for a secure connection.
Why Choose the SmartyCam External Power Cable
The Aim SmartyCam 7-Pin ECU CAN & External Power Cable is ideal if you want the reassurance of having your SmartyCam powered from your vehicles 12V system. It features CAN high and CAN low connection inputs for the ECU and is available in a choice of 2m or 4m cable lengths to suit a variety of motorsport setups.
  • 7-pin 712 male binder connector
  • For: SmartyCam Corsa & GP 2.2 & 3
  • 2m/4m cable
  • Constant 12V power supply
SKU: SM-ECU-EP
