Springe
Log ind
Søg her
Søg her Log ind Indkøbskurv 0
Indkøbskurv
Din indkøbskurv er tom
  • Fortsætte med at handle
    Skriv din besked
    I alt
    Se indkøbskurv
    Søg her
    Aim SmartyCam 3 Bullet Camera Replacement - AimShop.com
    Til SmartyCam Dual & GP
    Udskiftning eller reserve
    Choice of Lens
    Compact & Lightweight
    SM3-BC
    £315.00
    Choice of Lens
    • Del på facebook
    • Del på WhatsApp
    • Del på e-mail
    • Facebook Del på facebook
    • WhatsApp Del på WhatsApp
    • E-mail Del på e-mail
    £315.00
    The Aim SmartyCam 3 replacement Bullet Camera is a lightweight, robust replacement or spare part for your camera kit.
    High-quality camera Replacement for SmartyCam 3
    Compact & robust Lens options 67°, 87°, 120°
    Replacement Bullet Camera
    The Aim replacement bullet camera has been designed for motorsport and is incredibly light and robust.
    The bullet camera is black anodised, billet machined, small and compact enough to fit into the tightest of locations.
    Ideal to have one spare at the track in case your camera gets damaged.
    If you have multiple vehicles, you can have the correct lens for each specific vehicle.
    Provides high-quality footage.
    Lens Options
    The replacement bullet camera is available in three lens versions.
    The 67° lens is preferred for closed-roof cars, as it sees the track just within the windscreen pillars.
    The 87° lens is available for open roof and formula cars where it is possible to have a more ample view of the track.
    The 120° lens gives an even wider view of the track and surroundings.
    Please Note: This replacement Bullet Camera is for the SmartyCam 3.
    We also have Bullet replacement front glass kits available in three different lens applications.
    These are some of the items that can be added to your vehicle for incrementing performance and data.
    • Anodised black
    • Billet machined
    • Available in 67°, 87°, 120° lens
    • 1 x Replacement Bullet Camera
    • Lens option available 67°, 87°, 120°
    • Ofte stillede spørgsmål
    • Support videoer
    • Produktvejledning PDF
    • Kontakt os
    • Bliv ambassadør
    • Reparationer
    • Opdater siden
    • Åbn i et nyt vindue
