Springe
Log ind
Søg her
Søg her Log ind Indkøbskurv 0
Indkøbskurv
Din indkøbskurv er tom
  • Fortsætte med at handle
    Skriv din besked
    I alt
    Se indkøbskurv
    Søg her
    SmartyCam GP Roll Cage Mount For Recording Box - AimShop.com
    SM-VB-GP-R
    På lager, klar til afsendelse
    £80.00
    • Del på facebook
    • Del på WhatsApp
    • Del på e-mail
    • Facebook Del på facebook
    • WhatsApp Del på WhatsApp
    • E-mail Del på e-mail
    Product Image
    £80.00
    Aim SmartyCam GP HD Roll Cage Mount For Recording Box
    The SmartyCam GP HD can be installed using the GP HD roll cage mount. It is suitable for SmartyCam GP HD 2.1, 2.2 & 3 cameras.
    Secure mounting for SmartyCam
    Ball & socket system
    Complete with fitting kit
    GP 2.1, 2.2 & 3 Compatible
    The Aim SmartyCam GP HD roll cage mount for the recording box is for mounting the SmartyCam's recording box to a roll bar, railing or tubing.
    The roll bar mount has a unique ball and socket system which offers optimum positioning and has been designed to cope with the rigours of motorsport.
    The mount will keep the recording box safe and secure and can be placed in a position clear from the driver so it doesn't get in the way.
    Roll Cage Mount
    Securely attaches to any roll bar, railing or tube.
    AiM SmartyCam GP HD Roll Cage Mount For Recording Box 2.1 & 2.2
    • For use with SmartyCam 2.1 & 2.2 & 3 GP HD
    • Handlebar bracket
    • 90mm arm
    • Clamp base with ball
    • Mounting brackets
    • Locknut
    • Washers and screws
    Technical sheet Race Studio 3
    • Opdater siden
    • Åbn i et nyt vindue
