Connect Your System
The Aim ECU Plug & Play Cable has been specifically designed for TM Racing motocross bikes and can be used with the Solo 2 DL. The Plug & Play Cable is currently compatible with a range of TM Racing motocross bikes, including the SMX 450 F1, MX 450 F1, EN 450 F1, MX 250 F1 and EN 250 F1 (all from 2015).
Why Choose the Aim Solo 2 DL Plug & Play Cable
The Aim Solo 2 DL Plug & Play Cable is compatible with many models from the TM Racing line, making it suitable for a wide range of people using this motocross bike. Connected with a 712 7-pin male binder to the Solo 2 DL Lap Timer and a compatible connector for your TM Racing ECU, the cable provides a quick and easy way to log your ECU data.
TM Racing Motocross Bike
Plug & Play Compatibility
This Solo 2 DL Plug & Play Cable is compatible with the following TM Racing motocross models and years:
  • TM Racing SMX 450 F1 – From 2015
  • TM Racing MX 250 F1 – From 2015
  • TM Racing MX 450 F1 – From 2015
  • TM Racing EN 250 F1 – From 2015
  • TM Racing EN 450 F1 – From 2015
If you are unsure whether this ECU cable will fit your motocross bike, don't hesitate to contact our team.
  • For TM Racing SMX 450 F1, MX 250 F1, MX 450 F1, EN 250 F1 & EN 450 F1 (all from 2015) motocross bikes only
  • ECU cable for the Solo 2 DL Lap Timer
  • 7-pin 712 male binder connector
SKU: TM-MX-PP
Solo 2 DL TM Racing ECU brugervejledning
