Springe
Log ind
Søg her
Søg her Log ind Indkøbskurv 0
Indkøbskurv
Din indkøbskurv er tom
  • Fortsætte med at handle
    Skriv din besked
    I alt
    Se indkøbskurv
    Søg her
    Aim Solo Spare Backing Plate - AimShop.com
    SOLO-BP
    På lager, klar til afsendelse
    £30.00
    • Del på facebook
    • Del på WhatsApp
    • Del på e-mail
    • Facebook Del på facebook
    • WhatsApp Del på WhatsApp
    • E-mail Del på e-mail
    £30.00
    The Aim spare backing plate is designed for mounting the Solo GPS Lap Timer.
    Key Features:
    Spare backing plate Suitable for Solo GPS lap timer
    The Aim spare backing plate to suit the Solo enables you to mount your Solo to most flat surfaces. The Solo has two large integrated magnets on the back that hold it in place, so you can simply install or remove it with ease.
    Standard original mount ideal for use as a spare.
    Mount onto flat surfaces
    • 1 Solo Backing Plate
    • 2 screws
    • 2 washers
    • 2 nuts
    • Solo Backing Plate
    • Opdater siden
    • Åbn i et nyt vindue
