Aim Solo, Solo 2 & Solo 2 DL U Bolt Mount
Mount Your System
The Aim U Bolt Mount secures any Aim Solo GPS Lap Timer to your vehicle’s roll bar, railing or tube that has a diameter between 0.5 and 1.2 inches, so that you can easily and accurately measure your lap times.
Why Choose the Aim Solo U Bolt Mount
Designed specifically for the Aim Solo, Solo 2 and Solo 2 DL, the U bolt provides a strong and secure mounting solution, ensuring the lap timer won’t move, fall or cause any distractions. The dual swivel joint makes it easier to conveniently position the lap timer to face you, so that you can quickly monitor and improve your timings hands-free, without compromising on visibility.
Solo U Bolt Mount
