Springe
Log ind
Søg her
Søg her Log ind Indkøbskurv 1
Indkøbskurv
Du har gratis fragt!
  • AiM Car 5-inch TFT dash display with road icons for PDM08 and PDM32
    Aim 5" TFT Dash Display with Road Icons for PDM08/PDM32
    £295.00
    Fjern
Skriv din besked
I alt
£295.00
Se indkøbskurv
Søg her
AiM Accessories Deutsch DTM male and female plugs with pins and wedge lock connectors
P-DTM
Deutsch Male & Female DTM Plug & Pins including Wedge Lock
£8.00
  • Del på facebook
  • Del på WhatsApp
  • Del på e-mail
  • Facebook Del på facebook
  • WhatsApp Del på WhatsApp
  • E-mail Del på e-mail
£8.00
The Deutsch male & Female DTM Plug & Pins, including wedge lock, are ideal connectors for PDM use and are often used in engine compartments and transmission tunnels.
Male & Female DTM plugs Pins & wedge lock
2 to 12 way options
The plug & pins are suited for applications that require a secure & reliable connector in harsh environments, like under the hood of your car, transmission tunnels and other areas that need secure connections in both power and signal.
  • Tactile and audible connector mating
  • Rugged thermoplastic connector housing
  • Hand insertable/removable connects
  • Operating temperature range: -55 to +125°C
  • Positive contact retention
  • 1 x DTM Deutsch plug, pins, wedge lock
  • Ofte stillede spørgsmål
  • Support videoer
  • Produktvejledning PDF
  • Kontakt os
  • Bliv ambassadør
  • Reparationer
  • Opdater siden
  • Åbn i et nyt vindue
