Springe
Log ind
Søg her
Søg her Log ind Indkøbskurv 0
Indkøbskurv
Din indkøbskurv er tom
  • Fortsætte med at handle
    Skriv din besked
    I alt
    Se indkøbskurv
    Søg her
    Ducati Panigale 899, 959, 1199, 1199R, 1299 AiM Solo 2 DL & EVO4S Logger Plug & Play Cable - AimShop.com
    DUC-PP
    Ducati Panigale 899, 959, 1199, 1199R, 1299 Aim Solo 2 DL & EVO4S Logger Plug & Play Cable
    På lager, klar til afsendelse
    £70.00
    • Del på facebook
    • Del på WhatsApp
    • Del på e-mail
    • Facebook Del på facebook
    • WhatsApp Del på WhatsApp
    • E-mail Del på e-mail
    £70.00
    Ducati Panigale 899, 959, 1199, 1199R, 1299 AiM Solo 2 DL & EVO4S Plug & Play Cable
    The AiM ECU plug & play cable has been specifically designed for Ducati Panigale bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.
    Ducati Panigale plug & play cable 7 pin - 712 male binder connection
    Ducati Panigale Plug & Play ECU Cable
    The AiM ECU plug & play cable has been specifically designed for the Ducati Panigale bike. This plug & play cable can be used for the Solo 2 DL and EVO4S Data Logger.
    The plug & play cable currently fits the following Ducati Panigale bike models:
    899 Panigale - 2013-2015 959 Panigale - From 2016
    1199 Panigale - 2012-2014 1199R Panigale - 2015-2017
    1299 Panigale - 2015-2019
    Example data protocols
    • Below is a pinout drawing for the Ducati Panigale 899, 959, 1199, 1199R, 1299 plug & play connection cable
    • Ducati Panigale 899, 959, 1199, 1199R, 1299 Plug & Play connection cable
    Technical sheet Race Studio 3
    • Opdater siden
    • Åbn i et nyt vindue
