Springe
Log ind
Søg her
Søg her Log ind Indkøbskurv 1
Indkøbskurv
Du har gratis fragt!
  • AiM Car 5-inch MXm data logging dash with GPS display unit
    AiM 5" MXm Data Logging Dash with GPS
    Title:
    Default Title #MWS Options 3650803666
    £2,175.00
    Fjern
Skriv din besked
I alt
£2,175.00
Se indkøbskurv
Søg her
Link Nissan 350ZLink N350X PlugIn ECU module for Nissan 350Z performance tuning
Link Nissan 350Z N350X PlugIn ECU module for vehicle engine management
Link Nissan 350Z N350X PlugIn ECU, plug-in engine control unit module by Link
N350X
Link Nissan 350ZLink - N350X PlugIn ECU
Udsalgspris£1,165.50
Almindelig pris £1,295.00
  • Del på facebook
  • Del på WhatsApp
  • Del på e-mail
  • Facebook Del på facebook
  • WhatsApp Del på WhatsApp
  • E-mail Del på e-mail
Udsalgspris£1,165.50Almindelig pris £1,295.00
Easy to install. Affordable. Reliable
This ECU comes in its own enclosure, while the installation is a breeze with no alteration of the factory wiring loom required for the models listed below.
The N350X ECU is designed to suit the VQ35DE engine.
This ECU works with manual AND automatic transmissions.
ECU includes an onboard 4 bar or 7 bar MAP sensor.
Check the features tab for I/O expansion options
Highly recommended to fit an IAT sensor.
Suitable Applications:
2002 to 2006 Nissan 350Z (Fairlady Z Z33)
2003 to 2006 Nissan Skyline V35
2003 to 2006 Infinity G35
PlugIn Key Features:
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
Expansion connector 1
Gnd Sensor Ground Only
+5V Low Current +5V Supply
Aux 15 Auxiliary Output
Aux 14 Auxiliary Output
DI 8 Digital Input
DI 9 Digital Input
An Volt 8 Analog 0-5V input
Expansion connector 2
DI 11 Digital Input
Aux 16 Auxiliary Output
Aux 8 Auxiliary Output
  • G4X PlugIn ECU
  • Stickers
  • Ofte stillede spørgsmål
  • Support videoer
  • Produktvejledning PDF
  • Kontakt os
  • Bliv ambassadør
  • Reparationer
  • Opdater siden
  • Åbn i et nyt vindue
