Link 5 Bar MAP Sensor
The Link 5 bar MAP Variohm Eurosensor measures absolute pressures up to 5 bar, making it ideal for turbocharged or supercharged applications running up to 4.0 bar (58 PSI) of boost.
Why Choose the Link 5 Bar MAP Sensor
The Link 5 bar MAP Variohm Eurosensor can be mounted via a weld-on bung, tapped hole, or remotely using a barb, and is supplied with a plug and pins for straightforward installation. When using Link G4, G4+, or G4X ECUs, select ‘Variohm 5 Bar’ as the MAP sensor type in PC Link for proper calibration.
  • Includes 3-pin connector kit
  • Push wire through connector; crimp on terminal; pull wire/terminal back into connector
  • Calibration - 0kPa = 0.5V, 500kPa = 4.5V
  • PIN A = 0V
  • PIN B = 5V
  • PIN C = Signal
SKU: MAP5
PC Link downloads
