Springe
Log ind
Søg her
Søg her Log ind Indkøbskurv 1
Indkøbskurv
Du har gratis fragt!
  • AiM Accessories PDM32 pre-assigned 3m black car connection harness
    <tc>Aim</tc> PDM32 Forudtildelt 3m sort forbindelsesledning
    £230.00
    Fjern
Skriv din besked
I alt
£230.00
Se indkøbskurv
Søg her
Link BAL6 ballast resistor for ignition and injection systems, shown on a plain background
Link BAL6 ballast resistor for ignition and injection systems, shown on a white background
BAL6
Link Ballast Resistor (BAL6)
Udsalgspris£85.00
Almindelig pris £100.00
  • Del på facebook
  • Del på WhatsApp
  • Del på e-mail
  • Facebook Del på facebook
  • WhatsApp Del på WhatsApp
  • E-mail Del på e-mail
Udsalgspris£85.00Almindelig pris £100.00
For use with low-impedance injectors. Compatible with injectors with impedance between 2 and 6 Ohms. Please contact us if you are planning on using injectors with an impedance of fewer than 2 ohms.
Includes set of 6 x 4.7ohm 25w resistors mounted to a heatsink. These are also sold in a set of 4.
Note that injector ballast resistors get quite hot at high injector duty cycles. These should stay mounted on the supplied heat sink and be bolted to the chassis.
  • 6 x 4.7 ohm 25w mounted to a heatsink
  • Ofte stillede spørgsmål
  • Support videoer
  • Produktvejledning PDF
  • Kontakt os
  • Bliv ambassadør
  • Reparationer
  • Opdater siden
  • Åbn i et nyt vindue
