Springe
Log ind
Søg her
Søg her Log ind Indkøbskurv 0
Indkøbskurv
Din indkøbskurv er tom
  • Fortsætte med at handle
    Skriv din besked
    I alt
    Se indkøbskurv
    Søg her
    Link CAN Lambda Kit O2 exhaust sensor with Link CAN interface and wiring connector
    Link CAN Lambda Kit with Link O2 exhaust sensors for vehicle exhaust monitoring
    Link CAN Lambda Kit with Link O2 exhaust sensors for vehicle engine monitoring
    Link CAN Lambda kit with Link O2 exhaust sensors for vehicle exhaust monitoring
    Nøjagtig lambdamåling
    Bredbånd Bosch LSU 4.9 Sensor
    CAN datatransmission
    Aftermarket ECU Compatible
    CANLAM
    Link CAN Lambda Kit
    Udsalgspris£216.75
    Almindelig pris £255.00
    • Del på facebook
    • Del på WhatsApp
    • Del på e-mail
    • Facebook Del på facebook
    • WhatsApp Del på WhatsApp
    • E-mail Del på e-mail
    Link CAN Lambda Kit
    Udsalgspris£216.75Almindelig pris £255.00
    Link CAN Lambda
    Link’s CAN Lambda is an easy to use CAN module that provides digital wideband sensor control via CAN bus and is compatible with leading aftermarket ECUs.
    If using the CAN Lambda with a G4+/G4X PlugIn ECU use a Link CANPCB cable to access the CAN port on the PlugIn PCB and a Link CANF field insertable CAN plug.
    Please note proper CAN protocol must be followed.
    The CAN-Lambda’s ability to measure the proportion of oxygen in exhaust gases makes it an essential tool for accurately tuning fuel mixtures as well as allowing your ECU to make tuning adjustments
    on the fly.
    Being fully digital the CAN Lambda’s powerful LSU 4.9 sensor will eliminate any loss of signal, risk, delays and errors that analogue alternatives cause. The CAN-Lambda never requires free-air calibration.
    Dimensions
    Enclosure 60 x 26 x 15mm
    Lead length 170mm
    Weight 70g
    Input Voltage
    Controller 7.5 - 20 V
    Sensor 10.8 - 16.5 V
    Input Current
    Controller 100 mA
    Sensor Heater 8 A
    Operating Temp -20 - 100 deg.C
    Sensor Bosch LSU4.9
    Sensing Range 0.67 - 10 lambda
    CAN Frequency 1Mb/s,500kb/s,250kb/s,125kb/s
    Link CAN Lambda
    • CAN-Lambda Device
    • Bosch LSU 4.9 Sensor
    • Deutsch 4-way Connector Kit
    • 02 Bung and Plug
    • 2 Large Stickers
    • 2 Small Stickers
    • Quick Start Guide
    • Ofte stillede spørgsmål
    • Support videoer
    • Produktvejledning PDF
    • Kontakt os
    • Bliv ambassadør
    • Reparationer
    • Opdater siden
    • Åbn i et nyt vindue
