Springe
Log ind
Søg her
Søg her Log ind Indkøbskurv 1
Indkøbskurv
Du har gratis fragt!
  • Link Nissan S13Link NS13X PlugIn ECU module for Nissan S13
    Link Nissan S13Link - NS13X PlugIn ECU
    £1,246.50
    Fjern
Skriv din besked
I alt
£1,246.50
Se indkøbskurv
Søg her
Link EVOLink I-III EVO3X PlugIn ECU for Mitsubishi vehicles geschniegelt
Link Mitsubishi EVOLink I-III EVO3X PlugIn ECU for vehicle engine management
EVO3X
Link Mitsubishi EVOLink (I-III) - EVO3X PlugIn ECU
Udsalgspris£868.50
Almindelig pris £965.00
  • Del på facebook
  • Del på WhatsApp
  • Del på e-mail
  • Facebook Del på facebook
  • WhatsApp Del på WhatsApp
  • E-mail Del på e-mail
Udsalgspris£868.50Almindelig pris £965.00
This ECU is designed for the EVO 1-3 4G63 engine.
Includes onboard 4 bar MAP sensor
Air temp sensor highly recommended.
Suitable Applications:
Mitsubishi EVO 1 1992-1994*
Mitsubishi EVO 2 1994-1995*
Mitsubishi EVO 3 1995-1996*
*Chassis number for these cars should be CD9A or CE9A.
Mitsubishi GSR 1.8L 4G62
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
Expansion connector 1
Gnd Sensor Ground Only
+5V Low Current +5V Supply
DI 9 Digital Input
DI 8 Digital Input
Volt 5 Analog 0-5V input
Volt 6 Analog 0-5V input
Temp 3 Temperature sensor input
Temp 4 Temperature sensor input
Expansion connector 2
Ign 5 Ignition 5 Auxiliary Output
Volt 8 Analog 0-5V input
Volt 9 Analog 0-5V input
Volt 10 Analog 0-5V input
Volt 11 Analog 0-5V input
  • G4X PlugIn ECU
  • Stickers
  • Ofte stillede spørgsmål
  • Support videoer
  • Produktvejledning PDF
  • Kontakt os
  • Bliv ambassadør
  • Reparationer
  • Opdater siden
  • Åbn i et nyt vindue
