Springe
Log ind
Søg her
Søg her Log ind Indkøbskurv 0
Indkøbskurv
Din indkøbskurv er tom
  • Fortsætte med at handle
    Skriv din besked
    I alt
    Se indkøbskurv
    Søg her
    Link Audi TTLink - TTX PlugIn ECU - AimShop.com
    TTX
    Udsalgspris£1,345.50
    Almindelig pris £1,495.00
    • Del på facebook
    • Del på WhatsApp
    • Del på e-mail
    • Facebook Del på facebook
    • WhatsApp Del på WhatsApp
    • E-mail Del på e-mail
    Udsalgspris£1,345.50Almindelig pris £1,495.00
    G4X PlugIn ECUs offer the latest in engine management technology, designed to maximize the potential of your car.
    This ECU fits in the factory OEM location. Installation is a breeze, with no alteration of the factory wiring loom required for the models listed below.
    The Link G4X ECU TTLink TTX PlugIn Designed for the VWAG PQ34 1.8l Turbo engine with E-Throttle.
    This ECU works with manual transmissions only.
    Includes an onboard 4 bar or 7 bar MAP sensor.
    Suitable Applications:
    The engine must be 1.8T
    ECU header must have two connectors, 121 pin total
    Must be Drive by Wire (E-throttle)
    Must be manual transmission
    FWD or 4WD (Haldex)
    p to 6D fuel and ignition mapping
    Sequential fuel delivery
    OEM idle hardware supported
    CAN port
    USB tuning cable included
    Staged injection
    Knock with "windowing"
    Expansion connector 2
    There is no separate expansion connector on the TT Link.
    Pin 110 - An Temp 3
    Pin 111 - An Volt 10
    Pin 112 - DI9
    Pin 113 - Ign 6
    • G4X PlugIn ECU
    • Stickers
    Compatibility
    The following vehicles are known to be compatible:
    Audi TT - 99-02 - AJQ
    VW Beetle - 2005 - AWU
    VW Passat - 2000
    VW Golf - 2001 - AUM
    The following vehicles are likely to be compatible with the ECU, but are untested:
    Make
    Model
    Years
    Engine code
    Audi
    A3
    98-00
    AJQ
    A3
    99-00
    APP
    A3
    99-01
    ARZ
    A3
    00-05
    ARX
    A3
    00-05
    ARY
    A3
    00-05
    AUM
    A3
    00-05
    AUQ
    A4
    98-00
    APU
    A4
    00-02
    AVJ
    A4
    00-02
    AWT
    A4
    02-03
    BEX
    A4
    04-07
    BFB
    A6
    98-00
    APU
    A6
    00-02
    AWT
    S3
    98-01
    APY
    S3
    00-05
    BAM
    S3
    02-03
    AMK
    TT
    98-00
    APX
    TT
    99-00
    APP
    TT
    99-02
    AJQ
    TT
    00-02
    AMU
    TT
    00-05
    ARX
    TT
    00-05
    ARY
    TT
    00-05
    AUM
    TT
    00-05
    AUQ
    TT
    00-05
    BAM
    TT
    00-06
    AWP
    TT
    05-06
    BFV
    TT
    05-06
    BVP
    TT
    05-06
    BVR
    Seat
    Alhambra
    00-04
    AWC
    Ibiza
    99-00
    AQX
    Ibiza
    00-01
    AYP
    Ibiza
    04-08
    BJX
    Ibiza
    05-08
    BBU
    Leon
    98-00
    AJQ
    Leon
    99-00
    APP
    Leon
    00-01
    AJQ
    Leon
    00-05
    ARY
    Leon
    00-05
    AUQ
    Leon
    00-05
    BAM
    Leon
    02-03
    AMK
    Skoda
    Octavia
    99-01
    ARZ
    Octavia
    00-05
    ARX
    Octavia
    00-05
    ARY
    Octavia
    00-05
    AUM
    Octavia
    00-05
    AUQ
    VW
    Bora
    00-05
    ARX
    Bora
    00-05
    ARY
    Bora
    00-05
    AUM
    Bora
    00-05
    AUQ
    Bora
    02-06
    AWP
    Golf
    99-01
    ARZ
    Golf
    00-05
    ARX
    Golf
    00-05
    ARY
    Golf
    00-05
    AUM
    Golf
    00-05
    AUQ
    Golf
    02
    AWP
    Golf
    02-06
    AWP
    Jetta
    01-09
    AWP
    New Beetle
    99-00
    APH
    New Beetle
    99-00
    AVC
    New Beetle
    02-04
    AWP
    Passat
    98-00
    APU
    Passat
    00-02
    AWT
    Polo
    04-08
    BJX
    Polo
    05
    AWP
    Polo
    05-08
    BBU
    Sharan
    00-04
    AWC
    Vehicles with the following engine codes are known not to be compatible:
    AEB, AGU, AJH, AJL
    • Ofte stillede spørgsmål
    • Support videoer
    • Produktvejledning PDF
    • Kontakt os
    • Bliv ambassadør
    • Reparationer
    • Opdater siden
    • Åbn i et nyt vindue
