Springe
Log ind
Søg her
Søg her Log ind Indkøbskurv 1
Indkøbskurv
  • AiM Front Wheel Hub Speed Pickup Sensor for kart racing, black sensor with mounting hardware
    Aim Front Wheel Hub Speed Pickup Sensor
    £70.00
    Fjern
Skriv din besked
I alt
£70.00
Se indkøbskurv
Søg her
Link XS Expansion Loom #XSL cable for Link loom systems
Link XS Expansion Loom #XSL by Link for loom and cable exercises
XSL
Udsalgspris£29.75
Almindelig pris £35.00
  • Del på facebook
  • Del på WhatsApp
  • Del på e-mail
  • Facebook Del på facebook
  • WhatsApp Del på WhatsApp
  • E-mail Del på e-mail
Udsalgspris£29.75Almindelig pris £35.00
Want to add additional inputs/output to your Link Plugin ECU? Use the XS Loom. The Link XS Loom plugs into the expansion connector on all Link G4, G4+ and G4X plug-in ECUs.
The number of extra inputs and outputs added by the XS Loom is dependent on the Plugin ECU. For specific details check the plug-in ECUs specifications.
Common applications include but are not limited to:
Boost adjustment knob or switch
Wide-band AFR/Lambda
Oil Pressure Sensor
Fuel Pressure Sensor
Inlet Air Temperature (IAT) sensor
Map switch (Different tunes available via toggle switch)
The XS Loom is 2.5m long and uses 20AWG wire.
  • XS Loom 2.5m
  • Ofte stillede spørgsmål
  • Support videoer
  • Produktvejledning PDF
  • Kontakt os
  • Bliv ambassadør
  • Reparationer
  • Opdater siden
  • Åbn i et nyt vindue
