Second-Life MX2E Lotus Exige/Elise Dash
Choose Accessories
The Lotus OEM Upgrade: MX2E
The Aim MX2E provides a significant upgrade for Lotus Elise or Exige dashes, offering a seamless plug & play solution that provides real time data and enhanced functionality to transform your driving experience.
Why Choose the MX2E Lotus Dash
The Aim MX2E offers a comprehensive upgrade to your Lotus dash, combining modern aesthetics with advanced data logging capabilities. At the push of a button, your dash can be customised from daily driving to a track day data logger. Whether you're on the track or on the road, the MX2E plug & play dash provides everything you need to enhance your driving experience.
For Lotus Elise & Exige
The MX2E is compatible with Lotus Elise and Exige dashes that are fitted with Toyota engines:
- 2004-2007: Requires an additional adapter harness (airbag-equipped cars only).
- 2008-2020: Direct fit.
Advanced Data Acquisition
The MX2E dash logger gathers data from the car’s ECU, the integrated GPS module and any additional sensors and modules. This data is then displayed directly on the Lotus dash in real time, displaying key performance metrics like RPM, throttle position, temperatures, pressures, lap times and more.
The included GPS module provides accurate GPS speed, lap timing, and track mapping. You can view this track data directly from the dash or transfer it via Wi-Fi connection to our Race Studio 3 Software for more in-depth analysis. This will allow you to visualise graphs, histograms and tables to compare lap and session performance.
The MX2E dash has 2 types of displays, both available with analogue or digital: road or track. There are 16 display layouts to choose from with 4 different colour options, which can be customised to suit your preferences.
There is also a wide range of icons available on the display, allowing you to easily see important information whilst you’re driving: rear fog light, position lights on, ABS on/malfunctioning, ABS off, hand brake, engine off, pressure low, seat belt not fastened, airbag off.
The MX2E dash features a total of 18 solid LEDs: left or right direction indicators, 10 shift lights LEDs and 6 status information LEDs showing hand brake on, fuel level low, immobiliser on, position lights on, high beam on and engine problems.
The MX2E plug & play dash logger is compatible with various expansions and modules to enhance performance and expand on data collection. Compatible expansions include:
- Lambda Controller: Monitor your air-fuel ratio for optimal engine performance.
- SmartyCam Cameras: Integrate video with data overlay for comprehensive analysis. Analogue camera input also allows you to swap your display into a mirror camera through push button command or event management.
Harness Options
MX2E Dash
MX2E Fixings
Cluster
GPS09 modul
What is the MX2E Lotus plug & play dash logger kit?
The MX2E is a plug & play dash logger that is specifically for the Lotus Elise and Exige models. The MX2E kit is designed to replace the factory dashboard, comes with all required fittings, a dash cluster and a GPS Module and can be paired with many other Aim products like the SmartyCam 3 Series, the ACC3 and a CAN Expansion Keypad to enhance performance and expand on data collection.
What are the main features of the MX2E Lotus Elise / Exige kit?
The MX2E Lotus plug & play dash logger is designed to easily integrate and expand your Lotus Elise / Exige dashboard to provide a wider range of data capabilities. The MX2E has a fully customisable display and alarm system, as well as integrated LEDs, so it can meet your individual preferences and ensure that you can easily read your data on track. Its integrated shift lights can be personalised too, defining the RPM threshold on outputs, ECU values and more.
There are also delta times, which give instant insights into your performance on track by comparing your current lap to your best and showing exactly where you are losing or gaining seconds.
How is the MX2E installed in the Lotus dashboard?
The Aim MX2E dash is installed in the Lotus Elise / Exige (2004-2020) as a plug & play unit, typically requiring removal of the old dash, unscrewing four bolts, connecting it to the existing wiring harness and securing it to the cluster using the provided screws and fittings. For 2004–2007 airbag models, a specific adapter harness (V02593010) is required, which comes as an extra in the kit if selected.
Why won't the GPS pick up a signal?
Ensure that the MX2E Lotus dash firmware is updated to fix any bugs, add new features and improve hardware compatibility.
