Second Life Aim Taipan styrkontakt med standard kort kabel
Second Life
The Advanced Handlebar Switch
The Handlebar Switch (HBS) is a compact, high-performance, ergonomic handlebar switch by Aim. If you're looking for a highly flexible switch for your handlebars, HBS offers a complete solution with 2 push buttons and 10 integrated LEDs.
Why Choose the Handlebar Switch
You can activate traction control with the HBS to stop your wheels from spinning when you apply any excess power. The Handlebar Switch can also be used to activate launch control, which will assist you in accelerating from a standing start.
Up to 5 Selectable Maps
Taipan ECUs can manage up to 5 maps, and these maps can be selected by OEM switches, such as Honda, Husqvarna, and KTM. The Handlebar Switch makes this far easier!
Taipan ECUs and HBS are fully compatible with all the stock handlebar switches. Plus, the HBS allows the management of quick shifting on factory-equipped bikes.
