Springe
Log ind
Søg her
Søg her Log ind Indkøbskurv 0
Indkøbskurv
Din indkøbskurv er tom
  • Fortsætte med at handle
    Skriv din besked
    I alt
    Se indkøbskurv
    Søg her
    Super B Display BM01 12V/24V link battery monitor
    D
    £110.00
    • Del på facebook
    • Del på WhatsApp
    • Del på e-mail
    • Facebook Del på facebook
    • WhatsApp Del på WhatsApp
    • E-mail Del på e-mail
    £110.00
    superb lithium batteries
    The BM01 12-24V is a smart battery meter that can measure and display the voltage and the charge level (in percent) of a battery. It can also produce an alarm for a user programmable, low charge level. This device can be used for 12V and 24V applications Compatible with: Nomia and Epsilon
    Specifications
    PRODUCT SPECIFICATIONS
    Weight
    57.8 gr / 0.12 lbs
    Signal voltage (bat 1)
    6 VDC to 31 VDC
    Signal voltage (bat 2)
    0 VDC to 12 VDC
    Current consumption - Display on
    ± 20 mA
    Current consumption - Display off
    ± 8 mA
    Minimum cable diameter
    0.75 mm2
    Mounting Hole
    55 mm / 2.16"
    Installation depth
    18 mm / 0.7"
    Quickstart Guide
    Available to download Here
    User Manual
    Quickstart Guide
    • Ofte stillede spørgsmål
    • Support videoer
    • Produktvejledning PDF
    • Kontakt os
    • Bliv ambassadør
    • Reparationer
    • Opdater siden
    • Åbn i et nyt vindue
