This product is intended for Tillotson Racing only. If you have not been referred by Tillotson, please do not order this product.
The Aim MyChron 6 2T is our best-selling GPS lap timer with two sensor connections, specifically crafted for karting. Combining 30 years of experience with advanced technology, the MyChron 6 2T offers precise lap timing and advanced data analysis for both amateur and professional racers.
The MyChron 6 2T GPS Karting Lap Timer fitted to a red Aim Kart
Why Choose the MyChron 6 2T GPS Lap Timer 
The MyChron 6 2T GPS lap timer revolutionises how drivers and teams monitor and analyse performance on track.
Due to its highly accurate 25Hz GPS tracking, large screen displaying delta times and comprehensive data logging capabilities, the MyChron 6 2T provides detailed performance analysis from split times and overall delta time, racing lines, cornering speeds and braking points.
Please Note: The MyChron 6 2T is compatible with the most common heart rate monitors on the market.
Indlæs video: The advanced display features, and backlight colours, of the MyChron 6 2T
Advanced Display
The MyChron 6 2T features a wide graphical display, ensuring excellent readability. Brightness and contrast are automatically adjusted to maintain ideal visibility in all lighting conditions, and this allows drivers to clearly monitor not only their best vs current sector times, but also their heart rate, delta, delta bar graphs and more, allowing real time adjustments to be made, improving lap performance.
Indlæs video: Delta times LED display feedback on the MyChron 6 2T Lap Timer
Delta & Predictive LED Icons
An exclusive on-screen delta bar animation showcases instant graphical feedback on your live performance, showing how your current timing compares to your best.
LEDs also feature to display your Delta Times allowing you to set a reference lap and visualise where you are gaining and losing time. The integrated lights will display green or red accordingly.
Indlæs video: LED & Alarms System on the MyChron 6 2T
LED & Alarms System
Showcase of the MyChron 6 2T backlight colour options
The MyChron 6 2T has a sharp, high-contrast display which helps drivers easily identify the data displayed on screen, as well as 8 different backlight colours.
Indlæs video: Integrated shift light array interface and customisable alarms for the MyChron 6 2T
Cylinder Head Temperature Sensors, Exhaust Gas Temperature Sensors, and Water Temperature Sensors
Available Sensors
With the MyChron 6 2T, you can select two temperature sensors to monitor your engine more precisely. Choose from:
  • Cylinder Head Temperature (CHT) Sensor: This under plug sensor measures combustion heat, helping detect overheating from lean mixtures or aggressive tuning.
  • Exhaust Gas Temperature (EGT) Sensors: M5 and T12 sensors monitor exhaust temps to fine-tune fuel mixture and optimise performance.
  • Water Temperature Sensors: Available in M10 (for Rotax, X30, OK) and M5 gearbox versions, these sensors track coolant temps to prevent overheating, with the M5 also being useful for monitoring gearbox water cooling in shifter karts.
Choosing Your Sensors
Choosing the right pair depends on your engine type and what areas you want to monitor most closely. Using 2 temperature sensors together gives a deeper view of engine performance and reliability.
A popular combo is an EGT and CHT, ideal for air-cooled engines, providing insight into fuel mixture and combustion heat. EGT and water temp sensors suit water-cooled engines like Rotax or X30, balancing tuning with cooling system monitoring.
For shifter karts, pairing gearbox water temp (M5) with either EGT or CHT helps monitor both engine and gearbox temps, preventing wear. Some setups also run dual water temp sensors (M10 + M5) to track both engine and gearbox cooling separately.
The right pairing depends on your engine type and what you need to monitor; performance, cooling, or both.
Aim MyChron 6 2T analysis on Race Studio 3
Race Studio 3 Analysis
Your data can be downloaded via cable, Wi-Fi or Mini USB storage, and analysed in depth on your PC with Race Studio 3 software: charts, graphs and histograms will help you to understand your performance, finding out what needs to be improved.
You can compare the data that cannot be shown on displays, with a lot of dedicated views like track split report, channel report, SmartyCam videos and so on, also comparing different sessions.
Aim MyChron 6 2T Expansions; ACC3, Data Hub, SmartyCam 3, Tyre Temperature Kit, LCU-One S and more.
Upgrade your MyChron 6 2T lap timer with sensors and expansions for complete data control; OTK non-contact brake, throttle, and brake pressure kits track pedal travel and force, while wheel speed, water temp, CHT, EGT, and steering angle sensors deliver precise performance metrics.
The Data Hub multiplies CAN connections, with powered and non-powered options, with power coming from the 20-hour MyChron Lithium Battery, or a direct 12V external lead.
  • Display: Graphical
Integrated Track Database
  • Over 4,000 worldwide
  • Wi-Fi Connection: Yes
  • Bluetooth Connection: Yes
  • GPS: 25Hz
  • External Power: 9-15V
  • CAN Connections: 2
  • Connectors: 1 connector (binder) 712 fem 7 pins, 1 connector (binder) 712 fem 8 pins & 1 connector (binder) 712 fem 5 pins
  • USB Connection: For data download, mass storage support and battery charge
  • Temperature Inputs: 2
  • Digital Inputs: Optical lap signal, magnetic lap signal
  • External Modules: MyChron Expansions, IR Temperature Controller, SmartyCam 3 Series, Lambda (LCU-One and LCU1S)
  • Memory: 4GB
  • Battery Life: 20h approx.
  • Body: PA6 GS30%
  • Dimensions: 150.0 x 79.0 x 36.6mm
  • Weight: 370g
  • IP67
SKU: MY62T
MyChron 6 User Guide
MyChron 6 Tech Sheet
What are the key features of the Aim MyChron 6 2T?
The Aim MyChron 6 2T GPS Lap Timer is a high-performance piece of karting equipment that offers extremely advanced data logging capabilities. Along with heart rate, braking points, racing lines and more, it ensures that every second you're racing is monitored and recorded.
The MyChron 6 2T Lap Timer has delta times shown, letting you compare your current lap with others to see exactly where you are gaining or losing seconds in real time. The GPS module is also extremely accurate to 25Hz, allowing for advanced tracking capabilities and data collection.
Ultimately, lap timing and data collection are upgraded massively with the MyChron 6 2T Lap Timer, with multiple karting parameters being monitored and recorded for performance analysis.
How does the MyChron 6 2T Lap Timer work?
The Aim MyChron 6 2T GPS Lap Timer relies on satellite positioning, electromagnetic induction and thermal sensors to convert track data into readable information. Before you even start driving, the MyChron 6 connects to satellites and recognises the track using the automatic track recognition technology.
What software can the MyChron 6 2T Lap Timer use?
The MyChron 6 2T can be used with our free Race Studio 3 software for comprehensive data analysis and data management post-session to identify areas of improvement to remain competitive. Race Studio also allows you to configure and customise LED light arrays, sensor inputs, update firmware and more.
Does the MyChron 6 Lap Timer work with other Aim products?
What are the differences between the MyChron 6 and the MyChron 6 2T?
How does the MyChron 6 compare to the MyChron 5?
