Springe
Log ind
Søg her
Søg her Log ind Indkøbskurv 0
Indkøbskurv
Din indkøbskurv er tom
  • Fortsætte med at handle
    Skriv din besked
    I alt
    Se indkøbskurv
    Søg her
    Yamaha YZF-R1 & YZF-R6 AiM Solo 2 DL & EVO4S Logger Plug & Play Cable - AimShop.com
    YAM-2-PP
    Yamaha YZF-R1 & YZF-R6 Aim Solo 2 DL & EVO4S Logger Plug & Play Cable
    På lager, klar til afsendelse
    £60.00
    • Del på facebook
    • Del på WhatsApp
    • Del på e-mail
    • Facebook Del på facebook
    • WhatsApp Del på WhatsApp
    • E-mail Del på e-mail
    £60.00
    The AiM ECU plug & play cable has been specifically designed for Yamaha bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.
    Yamaha plug & play cable 7 pin - 712 male binder connection
    Yamaha Plug & Play ECU Cable
    The AiM ECU plug & play cable has been specifically designed for the Yamaha bike. This plug & play cable can be used for the Solo 2 DL and the EVO4S Data Logger.
    Yamaha YZF-R1 (YEC included) - 2004-2014 Yamaha YZF-R6 (YEC included) - 2004-2016
    Example data protocols
    • Below is a pinout drawing for the Yamaha Solo 2 DL & EVO4S Data Logger
    • Yamaha YZF-R1 & YZF-R6 Plug & Play connection cable
    Technical sheet Race Studio 3
    • Opdater siden
    • Åbn i et nyt vindue
