AiM GPS08 GPS Modul
Choose Accessories
AiM GPS08 GPS Modul
Precise GPS Tracking
GPS09 Pro Open Module activates instant lap tracking, recognising start/finish lines and details effortlessly. The Pro Open version of the GPS09 features a 6-axis 100Hz inertial platform and is connected via a CAN cable, which makes it quick and simple to install.
Why Choose the GPS09 Pro Open Module
The Aim GPS09 Pro Open Module guarantees precision and reliability, working with almost 20 satellites to improve its performance.
With an average of less than half a metre tolerance, the absolute precision of the GPS09 Pro Open Module determines exact vehicle position. The satellite signal uses rapidly locked moments after switching on the device, and there is no risk of missing signals due to noise or interference in the system.
On the Track
The GPS Pro Open Module is fast in satellite signal acquisition and reliable in adverse situations. GPS Manager allows you to set track start/finish lines and splits and to download a comprehensive track database. With the GPS09 Pro Open Module, you get important information, i.e. chassis analysis, track position, etc, as well as position, speed, cornering in-line and lateral G and automatic lap times.
With a Point to Point Mode available, maximise rally stage precision for superior cornering. This mode is crafted to elevate control and manoeuvrability, enhancing your overall driving experience through challenging stages. With Point to Point Mode, every turn becomes an opportunity to showcase skill and finesse on the track.
Open CAN Network
The Open CAN network on the GPS09 Pro Open Module facilitates seamless integration with various devices, allowing for comprehensive data sharing and analysis across the network. This means that connection between the Aim GPS and devices such as MoTeC, Bosch, Cosworth, Racelogic, VBOX and more is possible.
The Aim GPS09 Pro Open delivers real-time lap insights for peak racing performance. Capture lap and split times with comprehensive telemetry during track sessions, and optimise based on theoretical best laps for actionable insights when needed.
GPS09-Modul Pro geöffnet
How do you install the GPS09 Pro Open Module?
Installing the Aim GPS09 Pro Open Module involves mounting the antenna on a metal-free, unobstructed surface like the roof or top of the dash for maximum satellite visibility, then connecting the CAN (High/Low) or RS232 wires to your device.
What is the difference between the Aim GPS09 Module Open and the Aim GPS09 Module Pro Open?
Although both the Aim GPS09 Module Open and the GPS09 Module Pro Open provide standard GPS data like altitude, latitude, longitude, satellites number and position accuracy, the main difference is the integrated inertial measurement unit (IMU) in the Pro version. By featuring a 6-axis 100Hz IMU with a 3-axis accelerometer and 3-axis gyroscope, data collection will be more advanced with the Pro module.
Is GPS Manager used in the Aim GPS09 Module?
The Aim GPS09 Module uses GPS Manager software to provide accurate lap times and telemetry data, allowing you to effectively analyse your data and improve racing performance.
What is the difference between the Aim GPS08 and the GPS09?
The Aim GPS09 Module is essentially an upgraded and newer version of the Aim GPS08. The GPS09 has a more precise 25Hz GPS, faster signal locking and improved predictive lap timing.
What is the difference between the Aim GPS09 Pro Module and the GPS09 Pro Open version?
Although the Aim GPS09 Pro Module and the GPS09 Pro Open both deliver high-precision, 25Hz GPS data using multiple satellite constellations, their differences lie in their compatibility. The GPS09 Pro Open offers broader compatibility with non-Aim systems. In Race Studio 3, its CAN output can be converted into a CAN input protocol and incorporated into a merged/custom ECU protocol, allowing GPS data to be received through the ECU CAN stream. Alternatively, the standard GPS09 Pro Module is primarily designed as a direct plug and play expansion for Aim ecosystems.
Which products are compatible with the Aim GPS09 Pro Open Module?
The GPS09 Pro Open Module is designed to work seamlessly with Aim and non-Aim products and systems. It can be paired with third-party data loggers to get a comprehensive breakdown of your time on track.
- Supported Non-Aim Data Systems: MoTeC, Pi, Racelogic, VBOX, Cosworth, Bosch and other motorsport brands.
- Data/Dash Loggers: MXL2, MXS 1.3, MXP 1.3, MXG 1.3, MXM, MXT 1.3, MXK10 and MX2E.
- Strada Dash Displays: MXS 1.3 Strada, MXP 1.3 Strada, MXG 1.3 Strada and MXT 1.3 Strada.
- Internal GPS Units: Devices such as the Solo 2/Solo 2 DL and the MyChron 5/6 Series have internal GPS and do not require an additional external module.
