Kart Steering Angle Sensor
The Aim Steering Angle Sensor Kit is suitable for use with all Aim MyChron Kart Lap Timers/Data Loggers; the MyChron 6, 6 2T, 5S, 5S 2T and 4. It comes with a bracket for easy installation and is ideal for 1 revolution karting setups.
Why Choose the Steering Angle Rotary Potentiometer
The Steering Angle Rotary Potentiometer measures and records the driver’s steering input using a sensor (rotating potentiometer) to measure the displacement between two points. Using the Steering Angle Sensor, you can see where the driver is losing time due to steering angle; too much or too little at each corner.
Kart Steering Angle Sensor Connections
The Kart Steering Angle Sensor is available with or without a 712-719 male to female 4-pin patch lead, which is required to connect the sensor to a MyChron Expansion for the MyChron 5S, 5S 2T, and 4. For the MyChron 6 and 6 2T, the sensor will connect via a 712-712 male to female 4-pin patch lead with the ACC3 719 harness connectors.
Kart Steering Potentiometer Electrical Characteristics
  • Nominal Resistance: 10kΩ
  • Tolerance on the Resistance Value: ±5%
  • Precision (%): 0.034
Kart Steering Potentiometer Mechanical Characteristics
  • Mechanical Displacement: 270° +/-10°
  • Temperature Working Range: -55/+125°C
  • Dissipated Power at 40°C: 1.6W
  • Dissipated Power at 70°C: 1W
  • 4-pin binder 719 male connector
SKU: S-SA-K
Part Number: X05SNST01G
  • 1G Kart Lenkdrehpotentiometer
  • Zahnriemen
  • x2 Zahnriemenscheibe
  • Kart-Lenkwinkelsensorhalterung
  • Inbusschlüssel
Benutzerhandbuch für das Kart-Lenkpotentiometer
