AiM MXS, MXP & MXL2 Dash Halterung
Choose Accessories
Mount Your System
This Dash Bracket is a purpose-designed mounting plate made from 2mm thick raw stainless steel, tailored to securely hold the MXS, MXP or MXL2 Dash Display. It features a bolt-hole pattern of 160mm × 60mm to align with the dash unit.
Why Choose the Aim MXS, MXP & MXL2 Dash Bracket
The Aim MXS, MXP & MXL2 Dash Bracket allows you to mount your dash on a strong foundation such as the steering column using a centre hub mount, or directly to your chassis via weld-on or bolt-on tabs. The raw stainless steel construction delivers durability and a professional appearance.
This bracket provides a clean, solid mounting solution for your Dash Display (MXS, MXP or MXL2), ensuring optimal visibility and stability in any motorsport setup.
MXS/MXP/MXL2 Armaturenbretthalterung
