Kart Bremsposition Sensorhalterung
Mount Your System
The Aim Brake Position Sensor Bracket is a mounting bracket made specifically for use with the brake position sensor kit, designed for OTK karts.
Why Choose the Aim Brake Position Sensor Bracket
The Aim Brake Position Sensor Bracket is designed and engineered to firmly hold the brake position sensor in place, ensuring accuracy. It is the same bracket as supplied in the non-contact brake position kit, making it ideal for use as a spare or replacement. An OTK magnet holder is also available to purchase separately.
Please Note: The sensor is not included.
Halterung für Bremspositionssensor
