The Ultimate Track Day Kit
The Aim SmartyCam 4 Corsa & Solo 2 DL with double bracket is a must-have kit for competitive testing and track days. It combines the Solo 2 DL data logging lap timer with the SmartyCam 4 Corsa onboard motorsport camera with 85º angle lens, allowing you to easily review parameters such as speed, engine revs and cornering G-force against track position to see where lap times can be improved.
Video laden: SmartyCam 4 Corsa video footage showing Solo 2 DL in a motorsport setup
Accurate Lap Timing, Real Time & Post-Session Review
The Solo 2 DL lap timer provides key information: lap times, lap count, delta times and predictive lap times. With over 4,000 tracks already loaded onto the database from across the globe, you can automatically select your nearest track based on your current position.
Log your vehicle’s ECU data for reviewing after a race day to help improve driver performance or vehicle set-up, and capture every lap in full HD and overlay lap and ECU data onto the footage for the ultimate lap-by-lap review.
On-Screen Delta Feedback
Video laden: Showcase of the SmartyCam 4 Corsa features
Paired With The Best Onboard Motorsport Camera
The Aim SmartyCam 4 Corsa combines exceptional video quality with advanced data integration to give drivers and teams the information they need to improve performance. It automatically starts and stops recording using its integrated 3-axis accelerometer, allowing you to stay focused on driving.
At the heart of the camera is a Sony 12-megapixel CMOS sensor, delivering significantly improved image quality with sharper detail, better colour accuracy, and stronger low-light performance. An integrated LSI image stabiliser helps reduce vibration, optical distortion, and horizon movement, producing smooth, stable footage even in demanding track conditions.
Inertial Platform
The Solo 2 DL calculates, displays, and records lap times, sector times, position & vehicle speed, with a sampling rate of up to 25Hz, and 3D acceleration & gyro. This allows you to see your exact racing line, compare it to optimal lines for faster lap times, track your vehicle’s movements and provide detailed data on acceleration, braking and cornering forces.
The Solo 2 has a sharp, high-contrast display which helps sailors easily identify the data displayed on screen, as well as 8 different backlight colours.
The Solo 2 allows you to create a new temporary or permanent track layout too. Even if there is no map already, the device will create one for you.
Solo 2 lap timing features
Predictive Lap Timing
  • Best lap of the day
  • Best lap of the session
  • Previous lap
  • User reference lap
Video laden: SmartyCam 4 Corsa & Solo 2 DL data being analysed on Race Studio 3
Both the data recorded from the Solo 2 DL and the video from the SmartyCam 4 Corsa can also be combined in our free analysis software, Race Studio 3. This allows you to review your driving and compare data such as speed, G-forces, throttle position and more, and acts as a performance tool to assist you in improving your driving skills by providing a visual reference for driving lines and technique.
A Compact Mounting Solution
Providing a compact and neat mounting solution, both the Solo 2 DL and SmartyCam 4 Corsa can be secured in place on the included double bracket mounting frame. The kit can be mounted in the vehicle via a powerful suction cup for use on the windscreen or dashboard, or by securely fastening to a roll cage. This provides various options depending on circuit or driver requirements for a quick and easy transfer from vehicle to vehicle.
Solo 2 DL
  • Display: Graphical LCD
  • Integrated Track Database: Over 4,000 worldwide
  • Wi-Fi Connection: Yes
  • GPS: 25Hz
  • External Power: 9-15V
  • Memory: 4GB
SmartyCam 4 Corsa
  • CMOS Sensor: Sony 12 MP CMOS
  • Streaming: Via USB or Wi-Fi
  • Auto Power ON/OFF: Yes
  • Body: Anodised Aluminium
Solo 2 DL & SmartyCam 4 Corsa diagram
Pinouts
SmartyCam 4 Corsa Pinout Solo 2 DL pinout
  • SmartyCam 4 Corsa front view
    SmartyCam 4 Corsa
  • Solo 2 DL front view
    Solo 2 DL
    2x 12V Mains Charger
  • AiM Solo & Solo 2 & Solo 2 DL Suction Cup Mount - AimShop.com
    Suction Cup Mount
  • L Bracket
  • Cable icon
    Your Chosen Connection Cable
  • 22cm CAN EXP Cable
Solo 2 DL Tech Sheet
Solo 2 DL User Guide
SmartyCam 4 Corsa Tech Sheet
Videos
Overview
Video laden: An in-depth review of the main features and functions of the Aim Solo 2 DL track day lap timer.
How does the Aim Solo 2 DL motorsport lap timer work?
The Aim Solo 2 DL is a GPS lap timer that allows you to analyse instant speed, timing splits, live data and predictive, theoretical and delta times. It connects directly to the car's ECU and multiple satellite constellations (GPS and GLONASS), providing performance data in real time.
The Aim Solo 2 DL uses a range of different technologies to enhance user experience. It has a 25Hz GPS receiver for precise lap timings and position markers, a 100Hz 6-axis inertial platform that provides data on roll, pitch and yaw. It also has integrated data logging capabilities via CAN bus, for advanced and comprehensive data collection.
How do you connect the Aim Solo 2 DL to the car’s system?
The Aim Solo 2 DL manages all the hardware ECU connections as well as all the communication lines: CAN, RS232 or K-Line. Choose between the CAN/RS232 external power cable, CAN/K-Line/external power cable with the OBDII connector or RPM/external power cable. If your car doesn't have an ECU, you can connect the Solo 2 DL to an RPM wave to synchronise RPM to the position on the track thanks to the RPM power cable.
The Solo 2 DL can work seamlessly with our SmartyCam 3 series for data overlay and high-quality recordings. It can also be paired with an Aim ACC3 to add 4 additional analogue channels for external sensors. Data Hubs can also be added to the system to provide additional CAN channels, which is ideal if you're already using the CAN expansion port. Please see the "Connections" tab for more examples.
How do I mount the Aim SmartyCam 4 Corsa & Solo 2 DL Track Day Kit?
The Aim SmartyCam 4 Corsa & Solo 2 DL Track Day Kit comes with a double bracket to mount the devices in the same place. The suction cup double bracket provides a stable and vibration-resistant mounting solution, ensuring maximum visibility of your laps.
How do you add a new track to the Race Studio 3 database?
There are more than 4,000 pre-loaded track maps in the Race Studio 3 database. However, you can add an open or closed circuit in Menu > Type of Racing > Circuit Type, then select the "TRACK" and "CREATE" buttons. Follow the prompts onscreen or take a look at our track creation guide for more information on how to set up open or closed circuits.
