AiM SmartyCam HD & GP HD Verlängerungskabel CAN Harness Car
SmartyCam Microphone Cable
The Aim SmartyCam 7-Pin Female Jack Plug for External Microphone Cable is a 1m cable that has been designed to improve sound quality from your SmartyCam footage.
Why Choose the SmartyCam Jack Plug Microphone Cable
The 3.5mm female jack plug allows you to connect an external microphone to your camera. The microphone cable is 1 metre in length and plugs directly into the recording unit 7-pin 712 binder connection labelled ECU-MIC.
Please Note: This cable is only compatible with the SmartyCam 3 & 4 Corsa, 3 GP and 2.2 GP/GP HD. To use with the 2.1 camera, you will need to use the 7-Pin to 5-Pin Jack Plug Microphone Cable.
SmartyCam 7-Pin Jack Plug Microphone Cable
