AiM SmartyCam HD & GP HD Verlängerungskabel CAN Harness Car
SmartyCam Microphone Cable
The Aim SmartyCam 7-Pin Integrated Microphone Cable is a 1m cable that has been designed to improve sound quality from your SmartyCam footage.
Why Choose the Aim SmartyCam Integrated Microphone Cable
The microphone can be placed in any position you wish, inside or outside your vehicle and in a position where the microphone won't just pick up wind noise. The integrated microphone cable is 1 metre in length and plugs directly into the recording unit 7-pin 712 binder connection labelled ECU-MIC.
Please Note: This cable is only compatible with the SmartyCam 3 & 4 Corsa, 3 GP and 2.2 GP/GP HD. To use with the 2.1 camera, you will need to use the 7-Pin to 5-Pin Integrated Microphone Cable.
Integriertes SmartyCam-Mikrofonkabel
