Mount Your System
The Aim SmartyCam Bullet Camera Mini Roll Cage Mount has been designed to hold and position the bullet camera to a roll bar tube. It is compatible with the SmartyCam GP & Dual 2.1 & 2.2, 3 & 4.
Why Choose the Bullet Cam Mini Roll Cage Mount
The Aim SmartyCam Bullet Camera Mini Roll Cage Mount is manufactured from aluminium, with a black anodised finish and is designed to withstand the rigours of motorsport. The 2 jubilee clips allow for easily fitting the camera to different roll cage tube diameters, and the clamp is available with standard or extended lengths.
  • For use with SmartyCam GP & Dual 2.1 & 2.2, 3 & 4 bullet cameras
  • 2 jubilee clips (44mm & 55mm) allow for fitting to different roll cage tube diameters
  • Standard or extended lengths are available
  • Manufactured from aluminium with a black anodised finish
  • Designed to withstand the rigours of motorsport
SKU: SM-VB-GP
  • Aim bullet camera mini mount
    Ausgewählte Bullet-Cam-Halterung mit Klemme
  • 44mm & 55mm Jubilee Clips
    44 mm & 55 mm Jubiläumsklammern
