Connect Your System
The Aim Solo 2 External Power Cable fits with the Aim Solo 2 & 2 DL GPS Lap Timers and features a 5-pin 712 male binder connection, which goes into the GPS Lap Timer. The unterminated wires on the other end allow you to connect to an external battery. The high-quality cable length is 2m in total and is designed to withstand motorsport environments.
Why Choose the Aim Solo 2 Unterminated Power Cable
The Aim Solo 2/2 DL External Power Cable features a metal 712 screw-on connector with 5-pins in the housing, always ensuring reliable signal transmission in high-vibration environments. The other end has unterminated wires to connect to an external battery, ensuring the Solo 2 GPS Lap Timer has a reliable power source for the entire track day session. This ensures that you get the most out of your lap timer during track days, allowing you to view your data for an extended period of time.
  • 5-pin 712 male binder connection
  • Unterminated end with 2 wires: 12V+ & Ground
  • 2m length cable
  • Suitable for Solo 2 & Solo 2 DL
SKU: SOLO2-EXP
Solo 2 DL User Guide
